Re: Sealed bearings with inner spacer and...OUTER spacer??
JBOT Admin /
You shouldn’t have to center the inner spacer as it should be tight between the inner races, however if you had to add an od spacer, if it were plastic you could make it fatter to hold the inner in a centered position. I bet that’s what they did. Pics?
