You shouldn’t have to center the inner spacer as it should be tight between the inner races, however if you had to add an od spacer, if it were plastic you could make it fatter to hold the inner in a centered position. I bet that’s what they did. Pics?
Re: Sealed bearings with inner spacer and...OUTER spacer??
Subject | Written By | Posted |
Sealed bearings with inner spacer and...OUTER spacer??Topic by: JBOT Admin | JBOT Admin | 12/30/20 10:24PM |
Re: Sealed bearings with inner spacer and...OUTER spacer??Re: * wormdirt * | * wormdirt * | 12/30/20 11:17PM |
Re: Sealed bearings with inner spacer and...OUTER spacer??Re: baird co | baird co | 12/31/20 01:47PM |
Re: Sealed bearings with inner spacer and...OUTER spacer??Re: JBOT Admin | JBOT Admin | 12/31/20 08:52PM |
Re: Sealed bearings with inner spacer and...OUTER spacer??Re: Mike Boyd | Mike Boyd | 12/31/20 01:54PM |
Re: Sealed bearings with inner spacer and...OUTER spacer??Re: baird co | baird co | 12/31/20 05:05PM |
Re: Sealed bearings with inner spacer and...OUTER spacer??Re: todd amundson | todd amundson | 12/31/20 11:42PM |
Re: Sealed bearings with inner spacer and...OUTER spacer??Re: JBOT Admin | JBOT Admin | 01/01/21 10:16AM |
Re: Sealed bearings with inner spacer and...OUTER spacer??Re: 🇮🇹💦 Of the Loin | 🇮🇹💦 Of the Loin | 01/02/21 11:43AM |
