Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?
EH FCC of the QCB /
On that I’m not even going to risk burning it up.
The research I have done on the Kenitic CDI is that some Kenetics had the crank keyway in the correct place and other ones had the keyway about 40* Advanced from the vespa position. So if you put a Vespa crank in a kenitic and use the keyway it won’t fire in the correct position or Kenetic CDI on a Vespa it will be firing after TDC. The whole thing is a nightmare. So big picture is it is a crap shoot. After messing with Kenetic CDI stuff and not being able to crack the puzzle I am done......
Oh and another thing I got mine to fire in the correct position and running great, It just has low spark at lower RPMs which makes starting a pain in the asssssssss.
Points > Kenitic CDI
  Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Topic by: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/01/21 04:27PM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Dirty30 Dillon Dirty30 Dillon 01/01/21 05:13PM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Daniel '' Daniel '' 01/02/21 08:59AM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Dirty30 Dillon Dirty30 Dillon 01/02/21 09:55AM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: EH FCC of the QCB EH FCC of the QCB 01/02/21 11:21AM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Graham Motzing Graham Motzing 01/02/21 11:51AM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: EH FCC of the QCB EH FCC of the QCB 01/02/21 12:11PM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: P D P D 01/02/21 12:45PM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Thomas TPRF Thomas TPRF 01/03/21 01:03AM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/04/21 01:53AM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Graham Motzing Graham Motzing 01/04/21 10:45AM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Daniel '' Daniel '' 01/04/21 01:11PM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Dirty30 Dillon Dirty30 Dillon 01/04/21 02:00PM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Daniel '' Daniel '' 01/04/21 07:21PM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Graham Motzing Graham Motzing 01/04/21 08:55PM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Daniel '' Daniel '' 01/04/21 11:29PM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Dirty30 Dillon Dirty30 Dillon 01/05/21 09:22AM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Graham Motzing Graham Motzing 01/04/21 03:31PM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Graham Motzing Graham Motzing 01/04/21 03:34PM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Graham Motzing Graham Motzing 01/04/21 03:39PM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Graham Motzing Graham Motzing 01/05/21 12:27AM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Daniel '' Daniel '' 01/05/21 01:05AM
  Re: Kinetic CDI (Vespa) with Ducati Style CDI/Coil?Re: Graham Motzing Graham Motzing 01/05/21 09:44AM
