> Daniel '' Wrote:
> The Ducati unit that malossi used to make for Peugeot and mbk are
> adaptations from piaggio 2t bikes, I believe the px150 stator is the
> cheapest one to search. You can get the “kokusan” stator from puch shop
> now, which is one of the China clones made to fit puchs for about $200.
> I have bought them in the past on eBay for $30 to revive dead stators
> and they work surprisingly well with all of the rest of the stock parts.
> Ok back to the kinetic cdi. How would you be hooking this ignition up to
> a parma box? The kinetic cdi does have both a signal and power wire, so
> I’m confused why you all think it’s a normal one wire ignition like
> tomos a35.
On the Kinetic ignition, there is no separate pulse signal. If you look at the diagram, this is evident.
The white pole goes to the CDI box, and than straight to the ignition switch, to ground, so the killswitch pulls the ground from the ignition coil to stop spark.
Red would be the feed single wire to the Parmakit box, white goes to the ground prong/common.
