Re: Installing Airsal 65cc kit on my Puch Maxi
Brian F /
I definitely had to remove a bunch of material to get my circuit pipe to fit on that kit without leaking.
It'll run fine without matching the transfers, but you're leaving some power on the table that way. If you're rebuilding the bottom end anyway, which you should, matching the cases to whatever kit you're using is a no-brainer.
