Re: Pinto RR
Papa _ /
I want to redirect that last comment a bit.
My experience has been that a modded stock E50 (pipe, carb, mild porting) can happily run WOT all day and bomb hills without any danger.
My first maxi ran 35 on flat ground and mid to upper 40’s bombing hills. I had a Boss pipe too, which theoretically would let me rev into more dangerous territory than that circuit should.
I read posts, Jennings, asked some questions. Ride, listen, feel, then spend some time thinking about it. Eventually, you will have a more organic understanding of what is going on. You don’t have to be a scientist or engineer to go a little faster and not blow up.
Taking your top end off a lot is good too when you’re getting it all figured out. See where the heat is going. Maybe catch that ring blow-by early and correct it before something gets hot and stuck.
Like PD said, make sure there are no air leaks anywhere. No other tuning makes sense unless you are 100% positive the engine isn’t breathing through a hole it shouldn’t.
A tiny leak that barely causes a problem at idle may get more action when running full speed and pressure changes in the system are max. So, maybe you think the bing carb and intake are sealed well enough. Best to overkill and put an o-ring in there. Press them together tight and lock down the carb clamp. After that, only pull the carb via the intake nuts and leave those two clamped together while changing jets and needle settings. New intake gasket after that.
  Pinto RRTopic by: Carlos Campi Carlos Campi 01/09/21 06:20PM
  Re: Pinto RRRe: Chris Straub Chris Straub 01/09/21 06:46PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/10/21 12:53PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/10/21 04:12PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/11/21 02:51PM
  Re: Pinto RRRe: Thomas Peffer Thomas Peffer 01/11/21 09:04PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/12/21 10:31AM
  Re: Pinto RRRe: Papa _ Papa _ 01/10/21 04:41AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/10/21 12:54PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/10/21 12:20PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/10/21 12:59PM
  Re: Pinto RRRe: Chris Straub Chris Straub 01/10/21 04:01PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/11/21 02:50PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/12/21 10:44AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/12/21 11:17AM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/12/21 09:03PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/12/21 09:26PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/13/21 12:40AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/26/21 09:24AM
  Re: Pinto RRRe: Chris Straub Chris Straub 01/10/21 04:02PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/17/21 06:23PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/17/21 06:56PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/17/21 07:51PM
  Re: Pinto RRRe: Papa _ Papa _ 01/18/21 04:15AM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/18/21 10:34AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/18/21 11:39AM
  Re: Pinto RRRe: P D P D 01/18/21 11:52AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/18/21 03:27PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/18/21 06:40PM
  Re: Pinto RRRe: Papa _ Papa _ 01/19/21 03:40AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/19/21 09:27AM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/19/21 11:20AM
  Re: Pinto RRRe: Papa _ Papa _ 01/19/21 12:50PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/19/21 07:11PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/20/21 03:21PM
  Re: Pinto RRRe: Papa _ Papa _ 01/26/21 10:29AM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/26/21 11:04AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/26/21 11:16AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/26/21 11:11AM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/26/21 11:34AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/31/21 04:46PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 02/01/21 11:34AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 02/01/21 12:00PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 02/01/21 05:58PM
  Re: Pinto RRRe: Dirty30 Dillon Dirty30 Dillon 03/09/21 09:55AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 03/09/21 10:41AM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 03/09/21 10:45AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 02/01/21 10:10AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 03/08/21 09:05PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 03/09/21 01:15AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 03/09/21 08:43AM
  Re: Pinto RRRe: Garrett The Kid Garrett The Kid 03/22/21 01:09PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 03/22/21 10:29AM
