Re: Pinto RR
Papa _ /
Running no head gasket is fine if you polish the mating surfaces.
I am almost certain I learned that on MA. Mrrbrr even from the wiki?
Use a piece of plate glass and progressively finer sand paper. Figure 8s, 1/4 turn, more figure 8’s. It’s like prepping fiber optic cable (if that’s something you can relate to?)
It will raise compression some losing the gasket and removing a tiny bit of material when polishing. One less thing to worry about.
Torque is an elusive quantity. I mean, there is a proper number, but it’s not like you’re gonna set it and forget it. Each heat cycle, and all them good vibrations, is gonna work new shit loose.
After new gaskets and stuff, I get stuff what I feel is snug enough to not leak (real great answer; I know) ride around a bit and let it cool down. Things will be loose. Snug it back down. Repeat until you put a wrench on a cool fastener and it don’t want to be any more snug. Aluminum is easy to rip threads out of. Err on the side of caution.
You shouldn’t need thread lock or sealing goo on anything. Especially when you’re tuning because stuff is coming apart and going back on all the time. Those things can be great when you’re “done” so that things will stay put longer. I just make a habit of going over everything with a 10mm socket wrench after almost every ride. Trust, but verify.
A dab of anti-seize on the spark plug is extra security. Fresh spark plug gets 1/2 turn after the crush gasket engages the head. After the initial crush, next time you only give it 1/12 - 1/8 turn.
Just don’t over tighten anything. Nothing on a moped needs ham fisted torque. If it is leaking, it needs new gaskets or seals.
  Pinto RRTopic by: Carlos Campi Carlos Campi 01/09/21 06:20PM
  Re: Pinto RRRe: Chris Straub Chris Straub 01/09/21 06:46PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/10/21 12:53PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/10/21 04:12PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/11/21 02:51PM
  Re: Pinto RRRe: Thomas Peffer Thomas Peffer 01/11/21 09:04PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/12/21 10:31AM
  Re: Pinto RRRe: Papa _ Papa _ 01/10/21 04:41AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/10/21 12:54PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/10/21 12:20PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/10/21 12:59PM
  Re: Pinto RRRe: Chris Straub Chris Straub 01/10/21 04:01PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/11/21 02:50PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/12/21 10:44AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/12/21 11:17AM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/12/21 09:03PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/12/21 09:26PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/13/21 12:40AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/26/21 09:24AM
  Re: Pinto RRRe: Chris Straub Chris Straub 01/10/21 04:02PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/17/21 06:23PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/17/21 06:56PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/17/21 07:51PM
  Re: Pinto RRRe: Papa _ Papa _ 01/18/21 04:15AM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/18/21 10:34AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/18/21 11:39AM
  Re: Pinto RRRe: P D P D 01/18/21 11:52AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/18/21 03:27PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/18/21 06:40PM
  Re: Pinto RRRe: Papa _ Papa _ 01/19/21 03:40AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/19/21 09:27AM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/19/21 11:20AM
  Re: Pinto RRRe: Papa _ Papa _ 01/19/21 12:50PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/19/21 07:11PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/20/21 03:21PM
  Re: Pinto RRRe: Papa _ Papa _ 01/26/21 10:29AM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/26/21 11:04AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/26/21 11:16AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/26/21 11:11AM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 01/26/21 11:34AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 01/31/21 04:46PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 02/01/21 11:34AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 02/01/21 12:00PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 02/01/21 05:58PM
  Re: Pinto RRRe: Dirty30 Dillon Dirty30 Dillon 03/09/21 09:55AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 03/09/21 10:41AM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 03/09/21 10:45AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 02/01/21 10:10AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 03/08/21 09:05PM
  Re: Pinto RRRe: Jay Rivett Jay Rivett 03/09/21 01:15AM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 03/09/21 08:43AM
  Re: Pinto RRRe: Garrett The Kid Garrett The Kid 03/22/21 01:09PM
  Re: Pinto RRRe: Carlos Campi Carlos Campi 03/22/21 10:29AM
