> JBOT Admin Wrote:
> Ground is ground.
> Ground everything to the frame.
> Is this running yet? You need to time this at like 23 deg btdc. It
> starts there then will retard down to 18 or so which is usually safe
> with a decent head. This is for most Zuma jog a3202 boxes.
> Don’t time with the plug out duh.
> No point in checking that.
> Sometimes when you check timing and don’t have a good inductive signal
> the light will dance a bit. So where are ya now
Will investigate tonight. May pull stator apart to check wiring.
Explain why timing cant be set/checked w/ plug not in head but connected.
Cheers
