Re: NC50 Low End
Jack Rutherford /
Proma circuit pipe if you are willing to mod it to fit.
Search on here for clutch mods as well. Someone welded the gear to a different clutch. Or you can remove material from the stock clutch.
What's your compression? You can bump the compression to help with low end.
two speed or 1 speed? (edited)
