Piaggio Ciao Tuning and fixing
Hi guys!
I'm planning to tune up my old good Ciao for my little brother. (And for myself)
My idea is to change: Cylinder, clutch, carburetor, exhaust and air filter.
I would like to get best acceleration so if someone could give me some tips exactly what parts to choose or is there something else what I should change? :)
I link here the parts, that I have been looking for..
Cylinder:
https://www.scooter-center.com/en/cylinder-polini-63-cc-sport-oe43mm-piaggio-ciao-gudgeon-pin-oe-10mm-w/o-cylinder-head-p140006510st?number=P140006510ST
Clutch:
https://www.scooter-center.com/en/variator-kit-polini-piaggio-ciao-si-bravo-superbravo-grillo-boss-p241311?number=P241311
Carburetor, there are 2 models, not sure what is the difference:
https://www.scooter-center.com/en/carburator-malossi-sha-12/10-piaggio-ciao-boss-si-grillo-bravo-superbravo-px-ma01821?number=MA01821
https://www.scooter-center.com/en/carburator-malossi-sha-12/12-mix-piaggio-ciao-boss-si-grillo-bravo-superbravo-px-ma02245?number=MA02245
Exhaust, there is 3 models, not sure how to choose:
https://www.scooter-center.com/en/exhaust-polini-country-piaggio-ciao-bravo-p2000045?number=P2000045
https://www.scooter-center.com/en/exhaust-polini-top-one-piaggio-ciao-p2000104?number=P2000104
https://www.scooter-center.com/en/exhaust-polini-sport-piaggio-ciao-p2000132?number=P2000132
Air filter:
https://www.scooter-center.com/en/air-filter-malossi-piaggio-ciao-si-bravo-superbravo-grillo-boss-dellorto-sha-13mm-m043687?number=M043687
Thanks in advance! :)
Re: Piaggio Ciao Tuning and fixing
Cylinder: you've picked a 10mm pin. You're in Europe? Should be good.
Clutch: That's not a clutch. It is a CVT pulley. You need to check to see if your ciao is single speed (many are) or has the variable pulley system.
Carburetor : those are similar, but one has a 12mm venturi and one has a 10mm venturi. You want 12 for sure.
Exhaust: the first one will be disappointing, I think. The second two look pretty good.
Air Filter: it's fine. I usually chop the stock one and stuff some filter foam in it.
Don't forget, you will need to re-jet your carb to find the right mix. Also, you might consider upgrading your crankshaft. That will require a full rebuild, but worth it in the long run.
so jealous of the half pricing in europe so affordable, this sucks.
Hi!
Thank you for your suggestions :)
https://www.youtube.com/watch?app=desktop&v=5eMj9yxe2-Y
We have same system for "Clutch", can you tell me if its even possible install this:
One more idea.. all the carburators looks to be the same as original, only difference looks to be jet.
Maybe its wise to buy jet set? But I cannot find any suitable.. any suggestions?
I recommend either cutting the stock crank or using a Muzzachelli crank for broader intake timing. https://www.treatland.tv/mazzucchelli-vespa-10-pin-anticpato-race-crank-p/mazz-vespa-crankshaft-amt004.htm
Check out Carsten's video here:
There are many threads on this topic here too, this one looks promising: https://mopedarmy.com/forums/read.php?7,3961583,page=1
Well, no. The video shows a single speed system, which is typical of Ciao. If you have the same as the video, then no, what you linked will not work for you.
As far as jets, the carburetors are marked on the clamp where they attach to the engine and if you look carefully, the venturi sizes are different. You'll have to remove the airbox to see that.
You must change jets if you upgrade your engine. What is the right size? That is hard to say. There are so many possible combinations. Your bike probably has a jet in the 40s but I would guess that most upgrades will require upper 60s to low 80s, depending on what you do. There is a tuning sheet on the wiki somewhere.
