Derbi Variant Piston Port Specifications
(Redirected from Derbi - Piston Port Engine)
Engine
Specifications
  • Stroke: 43mm
  • Bore: 38mm
  • Displacement: 48.7cc
  • Compression 8.5:1
  • Rotation: CCW Facing Magneto
Transmission Oil
  • Capacity is 400cc (fill to the fill hole located under the pedal shaft)
  • SAE 80 EP (hard to find, do not use 80/90 that is gear oil)
  • SAE 20W50
Main Bearings
  • 17x40x12mm - 6203
  • 17x47x14mm - 6303
Main Seals
  • 17x28x6mm - Qty2
Case Bearings
  • 25x52x15mm - 6205
  • 15x42x13mm - 6302 (Watch out for cheap 6302 bearings, some come 16x42x13mm)
Case Seals
  • 16x24x4mm - Qty2
  • 15x30x7mm
  • 25x40x7mm
Carburetor
Stock Type
  • Dellorto 12/12
Jet Size
  • ? (probably somewhere in the 50s)
Ignition
Specifications
  • Motoplat
  • 6V 12-15W
Timing Advance
  • 1.8mm Before TDC (21 Degrees)
Point Gap
  • 0.35mm to 0.4mm
Spark Plug
  • NGK B7HS
  • Champion L82
Lighting
Bulbs
  • Headligh 6V 21W BA15s (1156)
  • Taillight 6V 5W BA15s (67)
  • Stoplight 6V 10W BA15s (67)
  • Speedo 6V 1.5W BA7s (3898)
Drivetrain
Belt
  • Dayco 8004
Variator Weights
  • 19.6mm x 14.375mm 10.5 Grams - Qty3
Chain
  • 415 Size
  • ? Links
Standard Front Sprocket
  • ? T
Standard Rear Sprocket
  • 30T
Variant Frame
Rear Shocks
  • 302mm Length
Headset Bearings
  • 3/16" loose ball bearings - Qty46
  • Bearing Services part #STL-3/16GR25
Spoked Wheel Bearings
  • 12x32x10mm - 6201-2RS - Qty4
Spoked Wheel Brake Pads
  • 105x20mm - Qty2
  • Tomos pads could fit with modification
Tires
  • 2.25" x 17"
Axle Size
  • 12mm
