Moped Wiki:Motobecane pre78 6v to 12v
(Redirected from Motobecane pre78 6v to 12v)
Here is a Hardwire conversion for the pre78 6v to use the 12v CDI le parte with the universal 12v regulator. You will be able to use the lights and the kill switch. If you switch over to the 2 prong brake light switches you will be able to use those.
pre78 6v to 12v CDI le parte HARDWIRE conversion
