Motobecane variator disassembly
From Moped Wiki
Here it is the best way I know of to crack open a variator without dealer tools: This is the WORST Way,heres a tool list: 36mm socket 1/2 " drive prefer 6 point MLM tool for a vise, buy at treatland. Oil filter wrench 14 to 16 inch oal hand impact driver and slotted bits note: this is a basic list.
Click the image to see the full scale version
Reasons to crack a variator:
- to grease the balls
- Removing a variator ball
- Shaving the back plate
- Installing a performance variating plate
- Using an AV7 variator on an AV10 motor
--Elldawg99 22:37, 11 December 2007 (EST)
Alternately,
- you can just drill a couple screws into your workbench to line up with these holes here or use 2 x 3/8in upside down drill bits mounted in vertically in a vice, set those holes onto it, thus immobilizing the assembly.
- Then use some muscle to loosen up the 36mm nut CCW (left hand) on the back plate and break it free with a long wrench (or use a spare set of handlebars for a lever).
- Once you break the nut free, use some big channel lock pliers to break free the back plate. This is clockwise CW or normal direction.
- also, I noticed that these screws here:
Had been locked in place with little dabs of weld. I had to clear out the slots with a flathead screwdriver and some firm but gentle hammer taps.
- I like this way better because there is much less chance of warping the variator with the vise.
