Puch Dealer Tools
From Moped Wiki
Jump to: navigation, search
Puch Dealer Tools
Each Puch dealer was issued a set of tools through Puch. These tools were specifically designed to be used on Puch bikes and engines. Many of these tools are rare and only a few are actually being used. Unless you are fortunate enough to find tools worth thousands of dollars in your grandparent's attic, you might want to replicate some tools for the ease of maintenance.
Puch Bench
  • table length 64"
  • table height 24.5"
  • table width 20"
  • base width 16"
  • base length 44"
Special thanks to boardmonger and mikerafter for pictures. Mikerafter also provided dimensions. More detailed dimensions are found in this thread [http://www.mopedarmy.com/forums/read.php?1,460225,786820 ]
End Play Measurement Tools
Special thanks to vic, hoppeness, and siddelicious for pictures.
Other tools
Other tools include an engine mount designed to fit in a vice, piston stops, bearing pullers, wrenches, screwdrivers, flywheel pullers, circlip pliers, clutch pullers and a few more. (Click on image, then "download high resolution version" for slightly larger images)
Special thanks to maxirider309 and harold for the pictures and the manual scans.
