Talk:Motobecane Quick Reference Guide
Damn you Rebel Moby, ya got me! guess i'll have to repeat your mantras: No spark - $8.95 for a DR60 condenser, replace the bonding strap and ground out the 6V terminal on the genny.
Throw on a SHA14:12 with a #53 and as long as the spi seals are not kaput you are good to go...
Always run the coldest plug which does not foul. WHen you pull a well seasoned plug the burn mark on the side electrode should be no further then the bend in the electrode. and finally: Jabbing at it with a screwdriver if it is stubborn is also an option
for those of you truly in need [[1]]
